Neutral light
Reevo
West midlands
Quick question
Out on my gs 1100 and neutral light is a bit hit and miss
When it’s not on I can’t start the bike
There’s a switch on the clutch
When I pull clutch in it still will not start
This is with the side stand up
Does this mean clutch switch is fooked
Cheers all
Quick question
Cheers all
Yes. The switch is out of order.
Connect the two switch wires together so you can start your bike again.
Be careful to pull the clutch anyhow because the bike will start moving at once if you don`t.
