Just received new products in from Italy
Fork Guards for all R1150GS/GSA and R1200GS/GSA
Effectively protects the most exposed part of the fork from dust, dirt and stones.
Includes both right and left Fork Guards with all necessary fittings and clear instructions to mount – installs in under 5 minutes.
Fork Guards
Frame Guards – for all R1200GS/GSA from 2004 onwards
These ABS Frame Guards protect the frame from impact or abrasion from boots or rough terrain and increase protection from dirt and mud.
Available either Black or Brushed Silver
Raid Crud Guard – versions for all R1200GS/GSA
The Raid Crud Guard is the Italian version of the popular Mudsling, designed to attach under the rear seat, keeping the rear of the motor and shock absorber clear of road grime, dirt, dust, and excessive water, even reducing mud build up if riding off-road.
Installs in minutes and includes all necessary fittings and instructions..
M001 - fits all BMW R1200GS and R1200GSA from 2004 - 2007 without ESA
M002 - fits all BMW R1200GS and R1200GSA from 2008 onwards without ESA
M003 - fits all BMW R1200GS and R1200GSA from 2008 onwards with ESA
Raidbox – for R1200GSA
With 3.5 liters of capacity, the Raidbox is great to store essential tools etc, with a lockable rear door big enough to gain access to all usable space.
Fits neatly and securely inside the right pannier frame, and is supplied with all necessary fixings for a simple install.
Fully waterproof so you can safely store a puncture kit, a first aid kit, anti-theft cables, locks, tools, etc. out of the way.
With the lockable rear door, you do not need to remove your pannier to gain access.
Made of durable ABS plastic with a lockable door and brackets in anodised aluminium and stainless steel fittings, and supplied with 2 keys. The Raidbox is designed to complement your BMW with a 'factory' appearance.
The Raidbox will fit all BMW R1200GS Adventure models from 2006 onwards with the factory fitted BMW Adventure pannier frames.
Raidbox
We've ordered in what we think is plenty of everything, so can ship same day, but if we get a run on this stuff and it's out of stock when you get round to ordering, we will be replenishing again before the end of this month (June 2012)
Fork Guards
Raidbox
