New KTM 990 SMT, 650 & 390 Adventure Bikes.
EVskiy
Handcrafting clients ideas in real time
Hertfordshire
Reading Motorrad & Reisen Magazine I have come across this article.
Apologies if some of the translation is a bit weird.
Page 108 Translation:
Since 2017, KTM has been offering models with the Rei-hen two-cylinder called LC8c in the middle class. In the future, people will think double-track in Mattighofen. And already a short time later, the thought of it matured in Mattighofen, in the future in addition to the winding costs. This is already their absence of the first reference to the first occurrence for a few months.
650 Adventure with this prototype.
Test bikes of a naked bi-ke offshoot, which due to the technical proximity to the
790 Duke and good camouflage is hardly distinguishable from this.
Proven things meet reduction
In addition, the engineers here still have the disguise of the short-
Upper middle class also in the one-
Revised 790 Adventure
Increase segment Twins to offer and
Prototype of the KTM 650 Adventure
Pulled, but later an egg-
Such a complete engine offer from
Will give way to a consistent design.
125 to 1,300 cc to create. So
In the meantime, however, a
To be expected is about a front mas-
A few years ago, about 490 cc
Prototype, which is on a 650 ke in 3D look, such as 990 Duke and
Measuring, almost completely new- Adventure indicates, and on this
1390 Super Duke they have received
He engine at partner Bajaj in India
Are the changes compared to the
And with the also the upcoming 390
Developed, the current model also made there more obvious
Adventure is waiting. In addition to the un-
Should be. But among other things, it is recognisable. Although this external differences are the technical pa-due to the too high complexity of the lich also for the purpose of camouflage rallelen with the platform donor
New development, it became difficult to still cover the 790 Ad-
790 Adventure, however, equally open-
To produce the project profitably, venture, but below it is clearly: For example, it seems and so a reduced version of new technology has already occurred here. This the swingar almost unchanged of the drive of the current 790 Duke is first of all to be taken over at the already final, as well as its place in the model planning.
Shaped tank to recognise. While
Spring strut. Also the external mark-
Are 650 and 790 Adventure as well
Male of the engine and its conversion
The goal is to use numerous existing parts
Closely related, as the new 650 field appear known, which suggests Duke and its predecessor 790, that the reduction of the Duke will be, but the bauchi-
Displacement here the most striking new
The obvious advantage of this is the two-part tank solution of the current. It will probably use many existing parts to mid-range adventures, there will also no longer be due to a shortening of the and the resulting lower de- in the future and so hubs are achieved like a reduction
Page 109 Translation:
The borehole. The result will be a reduced peak performance, but more accurate data is still speculative. We assume about 60 to 70 hp, as there is a gap in the offer of the Austrians. Due to less power and less weight, less effort must also be made for adequate braking force, which is why only one brake disc will be used on the front wheel in the future. As originally planned, production will take place at Bajaj in India, where future all entry-level models of KTM, Husqvarna and GasGas are to be produced.
The successor of the 890 becomes "Made in China"
In Mattighofen, you can now drive double tracks:
KTM 650 Adventure (top) and KTM 990 Adventure (below)
The stronger in-line two-cylinder models are to be produced closed by CFMoto in China in the future, which also concerns the successor of the 890 Adventure. The first prototypes of this are now also on the road. Although nothing can yet be recognised from the finished design, a look at the technology already leads to the conclusion that almost the entire motorcycle is being newly developed. The core element will be the new, stronger LC8c series twin with 947 cc, as it is also used in the 990 Duke. In this it produces 123 hp, in the Adventu-re version, the engineering area of which is also likely to be used a KTM drives two-track re again in favour of a better new radiator design.
Torque course on a few
This is divided here in two parts as with the So split the Mattighofener
PS do without. With the new Mon-big sister Super Adventure.
In the future, their offer in the middle
Tor goes, unlike the 650 Ad-
Class further up. And in a
Venture, a new exhaust system with a new SMT variant until 2026?
650 series, which will in the future
Accompanied by a larger collector.
More clearly addressed to beginners, and in
This makes, as with the Austria- The basic construction of the 990 divides the 990 series, which are now customary in price, a new
Adventure will also orient upwards again in the future, so
Swingarm necessary, which is in banana- an SMT variant. No wonder how the 990 Duke also winds this way mould over the collector. As if the 890 just presented is already pretends.
The exhaust itself will also be the result
SMT but successfully in the
Positioned lower in the future than started at the time of purchase. Nevertheless, 790 and 890 Adventure are also shooting. All this is already the successor 990 SMT
KTM 650 Adventure
Is a newly constructed Rah- now first test rounds. With closer • individual brake disc men. The rear frame will also be
Looking at it, however, this appears lo- • own tank construction
Newly developed and also apparently
Gisch: The current model came as
• own styling
Longer. Equally concise is, as additional variant only much later,
• otherwise closely related to 790 Adventure
At the little sister 650 Ad- with the model update of the Schwes-venture, the renunciation of the double model to the centre of the product- divided tank in the foot area. Instead of the cycle. In the future, the new SMT KTM 990 Adventure sen carries the prototype a classically available from the beginning. When • LC8c from 990 Duke positioned fuel barrel. Due to its exactly how far it will be, • two-part radiator design is apparently already difficult to foresee in the prototype, but before 2026 • newly developed frame builds dentliche capacity is definitely not too with it here either • new chassis, including swingar of the tank here very wide. In the front calculation.
• 990 SMT
Page 110 Translation:
Whether single cylinder with 44 hp for beginners or V2 with 160 hp in the upper price segment: At the moment KTM is able to offer a suitable adventure bike for almost all budgets. As a premise, this is usually the company's claim
"Ready to
Race", but especially the youngest member of the Adventure family, the 390 Adventure, falls a little out of the frame. Although she is stylistically based on her adult sisters 890 Adventure and 1290 Super Adventure, the current 390 Adventure hardly met the expectations of the Mattighofener to put a compact, affordable, but also off paved path capable bike on the wheels, was hardly true to the current 390 Adventure. Long before their presentation, they had experimented with a very off-road-focussed concept, which, it seems, was ultimately discarded in favour of the current model.
Significantly revised and off-road-oriented
The successor is expected to start sales in 2025 and current photos of almost series-ready pre-production models indicate that the current concept may have already become obsolete again. Because for the next generation of entry-level enduro, it seems not only the optics, but the same
110 Motorcycle & Travel
Established
"Split-Face" waived and
Instead displays three-dimensionally crafted headlights. The 990 Duke and the 1390 Super Duke R had only recently introduced this new look. Overall, also thanks to apparently grown dimensions in all directions, there is an extremely adult look that has very little in common with the current model.
LC4c single-cylinder the centrepiece
Technically, the new LC4c single-cylinder will also form the centrepiece here in the future, which recently premiered in the new 390 Duke. In the Adventure, the displacement will also be the already known 399 cc and the 45 hp peak power of the Duke sister also form a good guideline. At first glance, your frame will probably also be
The entire concept of the model of the 390 Duke was adopted, profoundly revised. Unlike things in a slightly revised form.
The current model and also different from the previous competitor
BMW G 310 GS waives the next
Fork and swingarm are new designs
Generation of the smallest adventure to be robust, but above all roadworthy.
21-inch front wheel, coarse studs and large travel
Although it should also be driven mainly on paved roads, the 21-inch front and 18-inch rear measuring rims, the coarse-stolli-ge tires and the very resistant chassis with considerably grown
Feather-
Already indicate that at least this road model can and should be seriously moved in unpaved run.
The rear swingar is a new design, apparently especially for the Adventure, possibly to take into account the future more robust design of the model. This also applies to the front fork, which apparently has a lot more travel than before. These changes, with the exception of the higher handlebar, will probably also be used for the first time on a 390 Enduro at the same time and an early prototype of a 390 Adventure with a larger tank, possibly a harbinger of a later tra-vel version, has already been spotted.
Production probably in India -
New KTM look also for the 390 from 2025
Adventure
Common to all future versions,
The styling reminds with its now equally probable steeply towering front and the
Sister model under the gas
Comparatively
High-mounted
Gas label, is that it will continue in the future
Spotlights with its two LED project shareholders Bajaj producing their two in- Indian Pune by Pierer Mobili-sect-like project shareholders Bajaj probably does not happen to produce on the. In the future, probably together the sister 450 Rally, which for years with all other single-cylinder models at the Dakar rally len from victory to victory and new models with 650s. Also included in the design - Twin. Working from spring 2025 at the latest, the new family face should be so far. the Austrian, who in the future will be on the
  • Like
Reactions: bod
I can't keep up with all the new bikes KTM bring out...
They are a bit of a joke I'd agree.
They try to re-invent the wheel with the 790 Adv, and within five years it's back to just under a litre.
Made in China. I’m out.
Not that I was in anyway. :D
The 650 Adv looks great!
Agree, if it has decent suspension (and maybe a free spare camshaft or a 4 year warranty).
I see KTM have today introduced their vat free offer on stock bikes, starting the clear out of models. Always a good way to piss off owners that purchased them at full price :D.
Anyone with an ounce of sense knows to never buy a KTM at any where near full list price ;)
£14,657.96 for a brand new 2024 1290 SAS looks good value (certainly compared to a 1300 GS) but will probably get even bigger discounts once they set a date for the release of the new 2025 1390 SAS/R.
Not sure what KTM are currently doing reference length of warranty as it keeps changing - my latest 2023 1290 SAR came with 4 years warranty :)
Yep, purchased my 1290 in December at a base price of £11990.00 plus options, which inlude full electronics pack but the off-road dongle, heated ergo seats, crash bars, intake pre-filters and asked for it to be registered in January of 2019 rather than December 2018.
When I come to sell it, it’ll appear to be a year newer 🤪
Be has to be desperate to buy a bike in the middle of a summer or spring. Buy it when dealers are desperate for your cash, and manufacturers pressurising them into more sales by offering deals on the next batch of orders. I however wouldn’t go back to the dealer I purchased my 1290 from. I like transparency.
If I said to my clients it’ll cost this much, then I stick with the price. Unless the client has requested for a change of spec, then that’s a different mater. I don’t go about my business telling one price then slap another lump on top, when I come to fit their project.
It looks like a number of KTM bikes are now available on their annual 'vat free' offer to clear the stock which is tempting. £8740 for a 690 Enduro R anyone 🤔 ? I'm just off to do an insurance quote....
It also sounds like they are finally clearing up the debacle of the camshafts properly (790/890) as owners are getting letters saying whether their model year is impacted, and even if it isnt a known impact year that they will be covered. About time too !
Good price for a new 690 👍
Same deal for the 701 https://www.ebay.co.uk/itm/31541272...rYnWlVAN9TqYuYFtYo=|tkp:Bk9SR6zO39a7ZA&edge=0
990 smt (r) when it arrives will be interesting. Once there is 120ish bhp version I will be booking a test ride. Currently on a 1290r Duke, had Multis, GS, etc
Sweet spot is light weight, 120-150 bhp, 17” front, wrapped up in a tall tourer/supermoto with screen. For my needs at least. With manual, not electric suspension set-up, thanks very much.
Reference: ‘ made in China’ Many parts come out of China these days. Made in ‘xyz’ just means unboxed and assembled elsewhere..
Looks like the next wave of 2025 bikes are about to be announced - 1390 Super Adventures mostly, but maybe a 990 SMT in there? Looks like there is going to be an auto gearbox as well?
