The fob is not waterproof, The transmitter output range diminishes over time, so you keep getting the warning light on the kombi, new batteries do not fix the issue - but a new fob at £200+ however does
Yes i can leave my physical key on the table, but the bike wont start or run without a physical key in the ignition.
Unlike a keyless, you can start it, go back inside to look for something and leave the fob away from the bike
Once started, it will stay running until its turned off, and if you dont have the fob, or plastic key with you ...
I'm not saying a physical key does not come with its own problems
Key freezing in the lock, ignition switch getting gummed up, but they cost a hell of a lot less to replace
