- Joined
- Sep 19, 2004
- Messages
- 6,554
- Reaction score
- 648
There are two YouTube , with guys showing the results , but no instructions on how it is done . (Sorry don't have a link )@ Hex Support........ I've just seen on Instagram, A Hex GS-911 software update from the standard 1200 TFT to the 1250 TFT, showing lean angle and sports dash.
Where can I find out more about this ? How to do it etc
Cheers![]()
That is great information. Thank you.Hi Both
The sport screen can be enabled from the Instrument Cluster service functions > coding configuration. Here you can set the sport mode to enabled, along with activating laps and changing your boot logo. Although the laps are traditionally used for racing, I personally like to set laps to review my lean angles at different rides. The only issue for me (I've logged a request with the developers) is that you need to start/end a lap with the flash to pass button, so when I toggle a strobe on flash to pass with the ezCAN, I start a new lap.
Although there is no practical use of the lean angles and break force, it remains pretty cool to have that on an adventure bikeI too enjoy the additional heated grips settings, as they just didn't balance it correctly with 2.
We do send out marketing mailers on these releases, but this should be improving in the new year.
Kind regards and safe travels
Hi Zx9manWhat bmw software version do you need to be able to configure these settings then
Are I see I have just updated the software on the gs-911 so will wait for further informationHi Zx9man
If your bike is equipped with a TFT and you've done a software update on this in the last 3 years, it should have the required i-LVL version that supports this update. I can get the specific version next week once our developers return from leave if you need it.
For the GS-911, you simply need to update to the latest software to be able to configure this.
Kind regards
Hi Zx9manAre I see I have just updated the software on the gs-911 so will wait for further information
Hi yes I had a few hrs the other day and sat down in my garage to have a play I indeed have the 6 heated grip settings but choose to use 4 as 100is easily divisible by 4Hi Zx9man
Minimum version for your CAFD on the ECUs needs to be 6 or higher, but like I said, if you've had a dealer update in the last 3 years, you'll be good to go
Kind regards
Can you do mine please as I hate the 2 heater settings!!Hi yes I had a few hrs the other day and sat down in my garage to have a play I indeed have the 6 heated grip settings but choose to use 4 as 100is easily divisible by 4
on the dash I have found the logos but not the settings to change from the gs dash to the m sport dash as yet
perhaps I need bigger glasses![]()
Hi P248I’ve just tried to add the Sports Menu and multi_level heated grip adjustments to my 2010 R1250GS using my GS911 USB (updated with the latest firmware just last week).
The GS911 connected to the bike properly and read all the fault codes, etc., but the options for the Sport Menu and heated grips were not showing anywhere. They didn’t appear greyed out suggesting that they weren’t available to me, they didn’t appear at all in any form anywhere in the GS911 functions menus.
Does anyone have any idea why that might be the case?
I think sports dash & 6x heated grips are TFT equipped models onlyI’ve just tried to add the Sports Menu and multi_level heated grip adjustments to my 2010 R1250GS using my GS911 USB (updated with the latest firmware just last week).
How else would you access a sports dash without TFT ? Strange thing to point outI think sports dash & 6x heated grips are TFT equipped models only
