New to a 1200GSA hexhead
Hubs
Totnes, Devon
Picked up a 1200GSA Hexhead last Sunday, and I've managed a couple of hundred miles on it so far. First time on a 1200, had a couple of 1150's and a 100GS before. However, it immediately felt like home. It's lower than I was expecting - still tiptoe for me, but manageable, and feels stable. I'm playing with tyre pressures to get it feeling right, although some of that might be a slightly squared rear tyre. The light steering, once I'd remembered how sensitive they are to counter steering with the wide bars, is a delight. Best of all, I no longer have to worry about being spat off on our pothole strewn roads. I hit a couple last night on the way back from Plymouth bike night which would have launched the VFR1200 into the hedgerow, and the GS just shrugged a bit and got on with it. A happy man!
Good choice, I look back fondly on my "transition" from an 1150 to a Hex.
About the only thing you should be thinking about is the suspension replace/refurb which will help it to last another 15 years.
The handbook on for my 2011 tc gsa recommends 2.2 f 2.5 r bar for rider with no luggage and 2.5f 2.9 r fully loaded .but these are recommended not set in stone .
For those old like me that uses PSI.
Hexhead R1200GS/A Quick Reference:
Front tire pressure – 32 one up, 36 PSI two up
Rear tire pressure – 36 one up, 40 PSI two up
PSI stands for "Pounds per Square Inch," which is a unit of measurement for pressure. It indicates the force exerted on one square inch of area.
These are what I use on my 2012/3 TCA GSA.
Great choice sir and if I may suggest a refurb of the Suspension front and rear by our very own Denz0 of this parish.
This will transform the bike to whichever you choose on a given day , a lovely and or lively ride once done .
The beauty is Denz0 can work with the original Suspension so no major costs involved
Best bike - I ever owned in 50 years of motorcycling !
