Newbie guide for changing wheel bearings?
Mav
Glos.
The wheel bearings are on the way out so I'm looking for an idiots guide to changing them. Have tried the search... it seems maybe it's obvious to everyone else!
Have seen suggestions around heating up the hub first, and also sticking the new bearings in the freezer before fitting them.
In terms of specifics for the HP2...
Pull the rubber cover off first? And they just pull out with a screw driver??
Then, I should be able to knock the bearing out gently from the other side using a screwdriver?
I see the inner spacer tube is loose - I'm assuming I have to move that a little to expose an edge of the bearing, right?
Before putting the new one in, should I be using any grease?
And the rubber cover... I'm assuming I can re-use that, or should I have got replacements for those too?
And yes, I know I should know how to do this! :blast
You pretty much just answered all you own questions,
a large socket will tap in the bearings once you get to a certain point, the bearings are sealed so you wont need grease, change the seals at the same time as you will hammer the old ones getting them out
The rear is a bit different:D
I've changed mine twice.
It's hard to get them out without damaging the hub: at least I found it so.
I ended up getting my dealer to remove the bearings at the same time I went in for my MOT: they hardly charged me anything.
And i put in new bearings.
I heated the hub up with a heat gun and put the bearings in the freezer: that really helps.
And got the right size of socket to gently tap in.
