no abs lights
MichaelD
Oxford
My abs warning lights do not come on at all, I've also not noticed any noises from the bike when pulling off. Is it safe to say the abs has been taken off permanently? Or is there a fault?
Thank you guys
Sounds electrical? Like a fuse(s) has gone? But I'm guessing you've checked them?
Sent from my SM-N910F using Tapatalk
Thank you guys
Certitudes are much better than assumptions. Simply pull the gas tank and see if the ABS pump is still there. Maybe your bike never even had ABS.
Lee
Quicker & easier way to do it
Look at rear hub (calliper side) & post a pic here
Is there a sensor ?
My one also has the ABS ring etc but the servo unit is on a shelf in the shed so ....no ABS lights :D
Is there a 'whizzy' sound when you apply the brakes, then if not you are lucky as a previous owner probably has your servo in a similar place to mine?
Mike.
