No Map on 2610
  • Thread starter Thread starter Bigmixer
Bigmixer
When I turn my 2610 on it reads the map info. and then is ready to navigate , showing my position on the map. After sitting stationary for about 15 minutes it shows "No Map" while still showing me what direction I am driving but no position. Do any of you clever chaps know how to fix this?
Bigmixer
Mouse,
I'll try re-seating the card and if that doesn't work I'll re-load the maps.
Thanks,
Bigmixer
Mine did the same thing today - suddenly showed no maps available. Turns out the CF card had worked loose about 2mm - shoved it back in & no more problem.
Regards,
Charles
Re-installed the card this afternoon, no change. I have just finished re-loading the maps onto the card, I''l keep you posted as to what happens
Bigmixer
The re-loading of the maps had no effect, when I thought about it this made sense as it was only the detail maps I was re-loading and when I lost the maps I lost the base-map as well. I rang Garmin tech. support and a very patient guy called Chris talked me through up-dating my sortware to ver. 4.30 (from 4.20) Bingo!! the base-map does not dissappear anymore. It also transpires that Ihad an issue with a "Jessop" brand CF card not being read, a change to SAN-DISK sorted that out, so I'm ready to rock 'n' roll!!!
Bigmixer
Sitting at the PC last night planning routes for a trip to Italy and the 2610 says "no map" ie not even a base map!! Rang them this morning and it's away for repair/replacement. Why does this only happen just before a trip?
Grrrrrrrrrrr!!!!
Rant over
Bigmixer
