No Network Connections visible but still online - warning - tech heavy!
andysdad
Northampton
W8.1 on a Dell PC - I was cleansing it and deleted the original user's profile (which worked fine) and now only have Guest with Admin privileges.
In Network and Sharing Centre there are no connections/adapters visible at all - no WiFi or Ethernet. Network says "unknown" and "access is denied" but web works albeit slowly via Ethernet. Hardware is there in Device Manager and I've removed/reinstalled both.
Much Googling says to add administrators to the localnetwork service but that fails with System Error 5 which is lack of admin privilege even though I ran CMD in Admin and confirmed the UAC box etc.!
It seems I am in a logical loop where a Guest Administrator cannot administrate. I can't add a new User in PC Settings. Just goes to desktop. I'm stumped.
Might have to rebuild PC from scratch.....
All suggestions (apart from buy a Mac, thank you) gratefully received.
A
Rebuild from scratch unless you can role the system back to before you deleted the admin account. Not sure if a system repair would help you out with a disk but probably not as you don't have an admin account.
Must have seemed like a good idea at the time to delete the admin account ;-/
Have you tried going back to a previous restore point?
Sent from my LG-K350 using Tapatalk
Thanks for the suggestions - I'll look at the domain trick.
I do have Admin privileges as Guest, the UAC box appears when it should but I cannot run CMD properly even though right-clicking CMD allows Run as Admin.
I've retrieved the W8 key and will rebuild but now I need an OEM Version disk (Dell) - anyone got one I could borrow a copy of?
Cheers,
A
People don't realise this but the first/original admin account is quite unique. Never tried it but I am actually surprised you can make the guest account t an admin. Might try it tomorrow just for a laugh.
Marki, the main Admin account can be hidden. Mine is but even though the Guest account details in "C\Windows\System32>net user guest" says it is in Group "Administrators", it isn't a real one.
I can start CMD with a right-click "Run as Administrator" but commands as above come back as System Error 5 which means the CMD prompt is not elevated administrator level. Very confusing.
Domain trick won't work on W8 Home Premium apparently.
Looks like a rebuild. I've got a non-OEM disk ISO and can go from there with Dell license.
I can't backup as File History is bust too and my old copy of Acronis is not W8 compatible. A right muddle I've made of this.
There is, of course, a renew PC command (cleans it for resale) but I didn't know that 8 hours ago :rolleyes:
