Hi guys thanks for the questions.
Bike has been running fine without any fault, I had just been out for a run and covered about 200 miles was on the way home and needed fuel, pulled in and killed the engine with the switch, filled up and went to start it, engine turned over fine but would not start, flicked the switch a few times still no joy, left it for about 10mins tried and it started, rode home about 80 miles parked up and went indoors, went out at night to put it in the garage and bike would not start, so pushed it.
next day tried again still no luck.
I have drained the fuel and removed the pump checked and its fine.
Pulled the plugs and no spark.
No signal at the injector either.
Put a hertz meter on and no signal so beleive it may be the engine sensor.
Have check the wiring as far as I can see and it seems fine.
All this leads me to think that the Hall Sensor is dead, do they just go and thats it or could it be the the engine kill switch is not powering up the relay, I can't get the cover off to check out the switch.
I don't normally use this switch to cut the engine and it's the only thing that is different to normal.
I need a wiring diagram if anyone has one, and how the hell does the cover come off? the starter button looks to big to go through the cover...
