noisy k75
de crowe
west of ireland
I recently acquired a 1993 reg k75. real oem suggests it was manufactured in late 1991 chassis number 0251519
In any event there is a nasty rumbling/ deep rattling noise toward the rear of the engine around the alternator area. I though it might be a fecked alternator but it seems to be charging as normal, producing around 12.5 volts on the multimeter. any suggestions as to what it might be. Kinda hoping it might have been the alternator as otherwise it might be bearings or some such horror.
Also the cooling fan does not working thus when it over heats it spits out coolant at the expansion contain/reservoir.
I am not too familiar with this model. round head light rubber thing at front of seat on tank, either does not have or is missing side panels,
Any thoughts.
a photo,
warning light on for abs, flashing centre and left
can't load photo!
A good alternator should be giving you more than 12.5 volts.
Take off the alternator and check drive cup and rubbers. Rubbers break up and vanes in drive cup can break.
I tried to poste this last night but the site kept telling me my token had expired
K75's have a bad habit of breaking alternator drive fins
Just inside where the frame makes a v just above the footrests on the right side
Take out the battery undo the spade and one wire on the alternator and undo the bolts around it and slip it back
There should be cush drive type rubbers separated by 3 alloy fins you'll probably find them broken
You can see the alternator drive "dog" in some pics here don't worry that's a K1200RS you can do yours through the battery box
... I am not too familiar with this model. round head light rubber thing at front of seat on tank ...
Model; K75C.
low seat model, i think. Hence no side panels and the pad. :nenau
The fans seize - you might get it working just with a little lube sprayed at it and turning it by hand. :nenau
Dr. F is usually spot on with his 'diagnosis-from-a-distance' (he's done it for me often enough :blush) and i've heard the same re; alternator drive fins.
Good Luck - keep us posted. :thumb2
k75
Thanks for that Jay and Marc,
I had it stripped down yesterday so that I could get at the alternator. I might get another chance tomorrow.
The cooling fan is not kicking in either so between the suspect alternator, abs stuff an cooling fan I have clearly acquired a puppy
Replace the fan with a cheap universal car one, that's what we did with my brothers fazer 1000, measure the space, buy one to fit the space!
Fuse 7 " lufter "
Also spin the fan and see if it turns by hand if it frees up or is already free they take forever to come in even in traffic
ABS probably just a reset needed especially if you have had the battery disconnected
Yep, it is either a Basic model, or the C model, with the low comfort seat - and they don't have side panels.
Totally different seat to the S model - shorter, and different fixing method.
As for the fan - could be either the connector nearby (they tend to corrode) OR the thermostat.
You haven't bought a pup - BMW's best built bike!!!
Mike
Mike
To be fair I was speaking a little tongue in cheek when I called it a puppy. It actually rides quite well and the body work is in good nick and the other issues are part of the joys of buying a relatively old, 21 years, well used cheap bike.Its condition was very much reflected in the price. It does have 80k+ on the clock.It gives me an opportunity to pretend I can be a mechanic.
I am a big fan of the K75, I have a 93 K75s which is being used within the family, and I had a K75rt until about 4 years ago.
Not the fuse, fuse ok.The fan as it appears to be stuck. It has been sitting up for a long time, an assuming the noise is the alternator, the drive is good, clutch and gearbox all seem fine.
Thanks.
model
when I said i wasn't familiar with the model, I mean this particular model K75, the only other one I have seen that looks like it is the white one stunningly restored by MikeP. But even that had a fairing of sorts.
Fuse 7 " lufter "
Just bridge the fan live terminal in the temperature relay. The fan should come on.
