Rotaxmaxracer
Sorry guys, but at risk of sending you all too sleep I have a question please on my 2006 Servo/ABS GS12. Recently kept having the rear brake light stay on (thereby disabling the servo). Took it to a local BMW specialist who ran a diagnostic on it and determined a fault on the front brake light switch.
He replaced the switch (which cured the fault) and the codes - but did say that it has originally indicated a over pressure fault code on the rear brake...so the problem MAY come back.
Didn't even get home until the problem remanifested itself (£190 lighter in pocket) and so I am guessing this is an ABS problem. I have read up on the Servoectomy articles here which remains an option, but was just exploring alternatives when I came across this company on the forum.
Can anyone tell me if this is likely to be the part causing the issue as I don't want to send this away if on the wrong track - unsure if it's the ECU/Pump or the modulator as I have heard reference to both?
http://www.ecutesting.com/catalogue/product/bmw_r1200_abs_pump__ecumodule_combined_amc108473.html
Have checked and lubed rear light connection and rear brake light switch seems to be working well?
Thanks in advance
Thanks in advance
