Not quite standard? 😁
Oldrat
Much better now Posh Pete is on ignore
'arrow, near the 'ill.
Just for fun, how many non Guzzi parts do you think are in this picture?
The head protector, the brass plate on the fuel tap, and something doesn’t look quite right about the rocker cover drain.
And it’s much, much, cleaner than mine
(Loose throttle cable though
Carbs/insulators/bands?
The braided whatsit to the ear of the head (cable covering)?
Good, but no cigar
  1. Stainless steel header pipe
  2. Dome nuts attaching collar,
  3. Tacho drive plugged,
  4. Different oil pressure sender,
  5. Oil feed line,
  6. Bolts attaching oil feed line and valve cover breather,
  7. Allen screws attaching valve cover,
  8. Cylinder head guard,
  9. Fuel tank,
  10. Hose clamp attaching fuel line,
  11. Fuel line,
  12. Stainless engine breather pipes
  13. Straight intake manifold,
  14. Screw plugging balance port in manifold, carb mount clamps,
  15. Screws attaching intake manifold,
  16. Silent Hektik HT lead
  17. Spark plug cap,
  18. Twin plugged
  19. Dipstick.
  20. Engraved brass petcock plate
  21. Painted Moto Guzzi motif
  22. Enricher (choke) assembly
Choke is very similar to mine, and I have stainless (rather than galv) hex screws holding the covers on, and hose clamps on the fuel lines. I did wonder about the carb headers, mine are slightly different, and angled, but I would not be surprised by “standard” straight ones on a different model. My oil drains are covered in woven metal mesh, but they’re not as pretty as that one.
Most of the rest is very difficult to see - though I can see the second plug lead now I’m looking for it!
Can we see the rest of it?
& Merry Christmas!
& Merry Christmas!
It’s already pretty well documented on here, but as you asked so nicely
