Canuck
Triple wire as you can see is connected to a CO2 pot on mine. If you're certain yours had no CO2 pot maybe there was something in the end to replace the pot/bypass it, maybe not. Are you sure you've not blown any fuses?
Where did you pull the panniers off?
Surely the remains of what's missing is knocking around somewhere to give you a clue?
Regards dave
Checked fuses... all good!
I pulled off the panniers in the garage... then drove away... I only noticed something was wrong when I heard some strange noise. Pulled over to see two wires hanging beside rear tyre. I found the triple plug in the garage... the other one must have hit my rear spoke or something as its nowhere to be found and was probably the noise I heard... only a few hundred feet from home but couldn't see anything anywhere. I suspect it got tangled in my rear wheel and yanked off
I'll post an update once I get it sorted out.
Many thanks.
