- Joined
- Dec 11, 2002
- Messages
- 2,663
- Reaction score
- 509
My 02 R1150GS has developed a really annoying ABS fault.
When I switch on the ABS will operate normally. If a ride for a bit then switch off, when I re-start the ABS lights flash alternately, ie ABS switched 'off'. If I then restart, sometimes the ABS works, sometimes it dosen't.
Occasionally the ABS lights both stay illuminated following a restart, although the brakes still work ... normally the ABS kicks in at about 3mph and the lights switch off.
During the winter I didn't use my bike for a while due to injury,and the battery went flat. I managed to resurrect it with an Optimate and now keep it on occasional trickle charge.
Could it be something to do with the battery? Crampie at Rydales reckons that the battery needs to be in tip-top condition to power up the ABS.
WTF is going on??
WTF is going on??
