Odyessy Battery Recovery possible
colin phillips
Cheshire
Last two weeks battrey drained, is it possible to recover one of these battries or is it bin job?
yes you can recover them.
A mate had a fault on his car that drained the Westco AGM battery (same type as the Odyssey). Initially his intelligent charger said the battery was dead. I suggested he connect another battery in parallel to the Westco and restart the charger.
This time the charger went through the initial test and started to charge the battery. After a minute or two the parallel battery was disconnected and, quite some time later, the Westco was fully charged.
A lead-acid battery that has been totally flattened for two weeks is goosed.
It may appear to have recovered but the total capacity will have been permanently reduced.
