OE aux lights
Scanners
Member
ELLESMERE PORT
The offside aux light packed in on my 2106 GSA TB so I took it apart thinking it was water ingress. Nope, dry as a bone. Took off the nearside one (which is working) and water pissed out of it! Swapped them over and the offside light now works on the nearside! So not the light then. It can't be a common fuse as the nearside works. Does anybody know if there is a fuse hidden somewhere for each light?
I installed some OEM lights on my 1200 GS 2017 a few days ago, seen no fuse anywhere on the wiring loom, I would put my money on the wiring harness socket wire that goes to the light that is not working correctly.
Smogbob - I tend to agree with you. So much so that I have ordered some cheap Cree copies and am going to bin the OE lights. I'll run the new lights through the EZcan. Oh, and the BWM lights were of 2 different styles so one of them had gone previously and been replaced by a later (?) style.
i had one go on my 2016 GSA, I was told they could not be stripped as they were a sealed unit ! it was just replace under warranty . My 2018 GSA has a different looking set of them on and have not let me down so far .
Yep the New bikes have the Nano version actually made by a different company called FAR, the older lights which I have are actually dated 2017 made by Hella, the Nano,s are far better, but thanks to a forum member I got a good deal so happy until something blows, then will switch to Nano, but must change the harness. ;)
