I'm rebuilding one at the moment
What can i say, fecking haynes manual is crap, ive yet to suss the cam timing, the haynes book goes from heads in one page to clutch slave cylinder the next,who wrote this drivel? feckin noddy?
This one grenaded the right exhaust valves,bits of blown up bike everywhere, debris even went back into to air box.I had the bike delivered partially stripped which didnt help.
If i were to guess, i would say it would probably be a tight tappet, not allowing the valve to seat fully and conduct the heat away through the valve seat.( i dont go with the side stand bollix)
The tighter the tappet, the less pressure from the valve spring can drag the valve into the seat thereby conducting the heat away.
Remember these are a set of unique circumstances which are all compounding and causing valve failure, however, i guess the failure rate to be very low.Albeit expensive.
Over a period of several miles at motorway speeds i guess it wouldnt be difficult to build up immense heat in the valve head.But it doesnt explain why only the right side.Dunno..But ..
The other thing which springs to mind is the air filter is fitted in the air box to one side,i wonder if it is slightly a gnats weak on the right side due to the air filter being mounted on the right of the air box,coupled with a tight tappet occuring because of slight valve train wear, and all these factors adding up and causing the problem.There is defineately a concoction of factors here causing the blow up.I dont think its just one thing.
Either way the haynes book is shyte, dont buy it.
