rudiemoto
Ok, the bike was taken for a proper test ride. The feedback was that the symptoms points towards the clutch slave cylinder. Dipping the clutch and then accelerating briskly in 4th gear causes the clutch to slip, yes the lever was fully released. So, thinking about it, fluid leaks past the slave cylinder making the return of the piston slower hence the clutch slip. Just after that the bike was accelerated without dipping the clutch and clutch slip. So we'll see what BMW makes of it under good will as the dealer has ordered the parts and work will be done next week.
The slave will not be at fault ,but remove the starter motor and check for oil
The clutch uses a pressure plate which the push rod can wear which make u thinks its the slave .
But I can be wrong
