Oil leak at 80(ish)?
Si Yates
North by West
Hi guys got a problem with the wifes 1100 get to about 80 and you get an oil splattered right boot?? Any thoughts on where I might look 1st before I start pulling it to bits?
Thanks for any advice in advance!
Could be the rocker cover inner seal, the cylinderhead, or being the R/H side could also possibly be the oil temp sender unit or the oil thermostat, both up on top of the engine on the righthand side
I've had that at speed on an 1100, 'twas the Barrel/Crankcase interface, can't remember if there is a gasket.
Donut on my was perished recently. Same result. Replaced all fine now.
