Oil level window - replacement?
gbpot
Teacake land
Can this be replaced?
I Can't see through the inspection window, all dark, (or is it all oil?).
Looks like a previous owner has cleaned it and left it scuffed. So can it be replaced?
Gavin
Lie the bike over towards the opposite side and get a mate to check the level window to see if the 'darkness' drops. If it does the bike is over-filled assuming of course you are checking it on a level surface with the bike upright. :nenau
or just start the bike
10 min job to replace if its knackered.
just poke a screw into it and pull it out
push home the replacement, the edges are just like a push fit oil seal
Or just start the bike.
Why did'nt I think of that? Ta guys. level is at the top of the red circle.
:bow
