Some advice please. I'm about to replace the oil site glass on my 2009 R1200 GSA as it's leaking. When installing the new one is it necessary to use a gasket of some kind and if so what's recommended?
Thanks for the reply and advice.Are you draining the oil or just leaning it back
Do you know how to get it out ??
Basically clean the area of corrosion well and maybe scothbrite the inset
there is usually a lock ring supplied with the new sightglass, only the later ones need it as far as I remember
If you can get the engine warm before you start It makes things easier than a freezing cold engine (metal contraction)
Some people lay it carefully on its right hand side so the oil drains away from the port and do all the operations like that
It takes about 5 minutes Be warned 1200 Hexhead rocker covers are paper thin and damage easily foam of rubber and a bit of plywood and someone holding the bike is adviseable
Get small drill and drill a hole and screw in a decent self tapper and prise it and the sightglass out with pliers or a nail bar
Clean the opening and scotchbrite it and locate the new sightglass and use a socket of just smaller than the outer diameter to tap it in home a very small smear of oil on the inner side of the sightglass rubber helps
Just tap the socket with a mallet and keep it square to the opening and it should go in easy!
N.B. Check for an inner lip that it rests against There should be but I am a bit brain foggy this morning ! If there isn't? Watch your depth so you don;t push it inside! I hope that drivel makes some sense
1 Drill a hole through the plastic outer in line with one of the holes in the shiny plate behind if possible(1) lever the thing out with screwdrivers. Is there a better way than brute force with a flathead screwdriver?
(2) So I just used a bit of oil to help seat the new sight glass. No gasket to seal?
Thanks mate1 Drill a hole through the plastic outer in line with one of the holes in the shiny plate behind if possible
Screw in a big self tapper to catch the hole edge behind and pry against that self tapper and lever against a small wooden block against the engine
Try to avoid prying on the edge of the recess for the sightglass!!!
2009 is showing the steel circlip ring LINKY Parts 2 & 3 So have a good look for that before you go hauling and pulling anything out
Take the old one out!
Clean the recess!
Slightest smear of oil to help it go in and away you go
(Remember to check for an inner edge that stops the seal falling inside the engine!!)
Leaking oil from thereWhy do you need to change the sight glass?
The sight glass either leaks or becomes opaque and therefore needs to be replaced.Why do you need to change the sight glass?
