TasGS
I've been doing a bit of reading on engine oils as my bike is due for some new stuff. I wanted to make sure I got it right after recently replacing cams and tappets after the last ones looked like this:
Some thoughts from my reading, is it a possibility or am I way off track?
Chance that the wear and lack of ZDDP in the oil are related? Anyone posted similar thoughts/discussed this before? I tried searching but couldn't find anything...
- BMW suggests SF/SG/SH oil for the GS
- These oils are now 'obsolete' as they have had the zinc and phosphate levels reduced to comply with modern environmental requirements
- Traditionally flat tappet cams have required zinc and phosphate (zinc dialkyldithiophosphate - ZDDP) in the oils as it forms a coating that stops wear between the cam and tappet
- See this - (WFS) - http://www.hotrod.com/techarticles/engine/flat_tappet_cam_tech/viewall.html
