On behalf of a friend (idling issue)
Badgs
Uk
R1200GS idling issue.
The idle seems to be very erratic. Whether hot or cold it settles randomly but sometimes hangs at 1800rpm.
New throttle position sensor installed, cables checked, throttle bodies balanced about 2000 miles ago and no worrying engine lights etc.
When bike is idling and the stepper motors are disconnected it doesn’t make any difference. Is this correct? What else should I be looking for?
Thank you for your help.
As no one has come back to you on this here is my 2 pence worth.
As the throttle cables are not hung up and I assume that you have free play on both cables when the throttle is off, it sounds like a vacuum leak . The bungs were replaced after the balancing?
Did you reset the idle motor calibration before fitting a new TPS ? Did the TPS show up in the fault codes ? Have you reset all adaptations after fitting the new TPS ? .. by resetting all adaptations you’ll also reset the idle calibration...
Thanks guys.
Yes to replacing the bungs but no to the items Steptoe mentioned.
We were told to put the TPS on, Switch on ignition, Rotate throttle to max and min three times, Wait 5 mins and start the bike.
Please can you advise on the correct steps after TPS replacement to reset adaptations and the idle calibration?
Thank you
Thanks guys.
Thank you
You need a GS-911 diagnostic tool. Plug in and press a couple buttons to calibrate throttle body idle motors re-set all adaptations. That may have been all you needed to fix your initial idling problem.
Thank you for this. That’s ace.
What is the best place to get a GS-911 from? I’ve got an R1150GS Adv and my friend has an R1200GS (2004) so we could share one.
Does any one have one that would work for these for sale?
If you pay for your subscription you can access the for sale section. They come up for sale from time to time.
Same as my issue... Mine comes back to idle but not straight away
