one for the mechanic types
bowser
Gloucester
R1100GS
I am in the process of replacing my clutch, and the needle bearing in the release arm is fecked that's not a problem I have a replacement on order however there is a small bush or sleeve that fits inside the bearing that the mounting bolt fits through.
Now I have checked all of the on-line microfiche and nowhere can I find this little part. It is not listed as comming with the arm, it does not come with the bearing, I have looked for a part number for the bolt to see if it comes with the bolt however the bolt is not listed, it is shown on the exploded diagram as No 10 however the list that accompanies the picture only shows up to 9 and the bolt is not listed ???
Anyone got any idea what I am talking about and part numbers or what fiche that part is shown on ???
If you do a part no search for the bearing on realOEM it shows everything else it fits. Try selecting an R100 of similar age and it shows the bolt with a sleeve and locknut. Does this look anything like yours?
HTH
Dick
HTH
Dick
that was the web site I was looking at if you look at the 1100
http://realoem.com/bmw/showparts.do?model=0404&mospid=51667&btnr=21_0082&hg=21&fg=51
it shows the bolt but no part number and no info and only shows the needle bearing
however as you say the R100 arm shows the same needle bearing and as you say shows the bold and the sleeve.
http://realoem.com/bmw/showparts.do?model=0459&mospid=51665&btnr=21_0086&hg=21&fg=51
I will ring the dealers in the morning thanks for your help.
Visited the links you supplied and got distracted by all the ads for Russian women! :hug
There's an hour of my life I'll never get back... :blast
you do realise that the site uses targeted ads, so the ads you see are based on your browsing habits, and different from the ones everyone else see?
Just for your info I got ads for camping gear and watches
Mine were for anoraks and slippers :tears
