Optimate connection for 2010 990 Advent
jaca2865
Scotland
guys and galls
what is the right optimate connection to use for charging the 990 Advent 2010 model via the power socket and where can i get one?
thansk
Buy the correct optimate lead for you model, if they do one! Google is your friend!
Mine did but, I couldn't be arsed buying one (read, impatient) so used a spare 3/4 socket plug that I had in the garage and chopped the plastic bit off the end of the optimate lead, and wired/soldered it onto the 3/4 size plug :D
Never had a problem, just plug it into the socket and away yer go.
Mines an Optimate3 BTW
HTHs
I just used the standard Optimate jack plug that comes in the kit on my 950SMR. Attached it to the battery and cable tied the other end to the frame
Bob's Yer Uncle :thumb
many thanks guys. really helpful and am grateful. obliged.
have ordered a ktm plug for the socket on the dash of the 990 Advent and will rewire an Optimate cable with the white connex on the end to make it fit the optimate charger!!
bought the plug from Drysdales in Perth!!
Robert is indeed my parents brother! Nae tother a ba. Which translates to: this little affair was no trouble whatsoever in finding a solution :flag :beerjug:
