73Octane - Your information is somewhat misleading to those who aren't 'in the know' I've no idea who this 'Colin Coles' is, but methinks he's scaremongering...
MikeHave isn't trying to use 'any' battery charger - hies specifically said he's using an Optimate - a modern 'state of the art' battery charger. It will never delever 'too much charge', unless it goes faulty in a somewhat extremely unlikely way. Optimates are neither trickle or 'taper' chargers (a term I've never heard of before) They are computer controlled and recommended by virtually every bike manufacturer.
Pulse charging is only used to de-sulphate batteries - it's not a charging method.
No modern motorcycle battery I know of is anything other than a fully sealed type. Do you really think someone would an unsealed battery that would leak battery acid when the bike's on the side stand
unwavering voltage will allow the battery to eventually begin to sulfate
What??? Unwavering means 'does not change. A fully charged battery is the
only way of preventing sulphation.
There is absolutely no need to 'allow a battery to rest' every 60 days. That article is misleading it beggars belief... I mean
you need to monitor the battery occasionally for correct fluid level
FFS!!!!
I recommend that you unplug the charger at least once every 60 days during seasonal storage
Why? Where is the scientific backing for this???
There may be other motorcycle units that do that, but I’m not aware of any
Errr - Optimates, Oxford Maximiser's etc etc etc....
