".....Who leaves there optimate on all the time ? I have just been told that it fry's the batteries....." The whole point about an Optimate is that it CAN be safely left on all the time. It will automatically cut out charging when the battery is fully charged.
Incidentally a little vaseline on the terminals is a good idea
I used to leave my Optimate connected all the time to a Buell X1 Lightening, a Yam Fazer 1000 and then a Kwak ZX7R without
ever having a problem. I then did the same with my 1150GS, fitted with a new genuine battery, and after about 10 months the battery was 'brown bread'.
I believe the dead battery was to do with the
type of battery it was, i.e. AGM, rather than any fault with the Optimate; the Optimate just couldn't charge it properly.
I have heard stories of Optimates frying batteries, but have never experienced it. However, the price of new batteries being relatively high, and the fear of coming out to a dead/fried one, it does kinda make you a bit cautious. But as I've mentioned, it never fried any of mine and I don't believe the BM failure was a fault of the Optimate.
I used to leave a
Ctek 3600 permanently attached to my poor departed Moggy (
) and will leave it connected to the MX-5
JB ) when it's laid up. This seems to be a good charger which is capable of charging AGMs, but I'm still a bit wary of leaving it on the GS
. I tend to put it on till the lights turn green then disconnect it. I've got an email from Ctek tech support with their recommendations for BMW/AGM batteries but it's on a different PC, I'll see if I can find it and post it up.
One thing I did find with the Optimate was that it wasn't very good at actually charging a flat battery. It will charge it so far, but not give it a full charge; it tends more to 'maintain' the existing level of charge. The Ctek on the other hand will fully charge a flat battery, but then Ctek say it is designed to and it is a 'beefier' charger capable of handling a wider range of battery sizes/amperages.
