OSM maps and how to put them onto a card
dicktheleg
Pestie to the Nobility
Worcestershire, England
Is anyone able ( and willing) to put a copy of OSM France maps onto a micro SD card for me.
I’ve looked at the process and I’ll admit I’m baffled.
I’ll supply the card obviously.
It’s to be used in a Garmin Drivesmart 55.
Thanks in advance
Rich.
Title edited.
Richard
Oh! This might help.
To put a copy of OSM France maps onto a micro SD card, download the map file (usually named gmapsupp.img) and copy it into the GARMIN folder on the micro SD card. Ensure the card is formatted to FAT or FAT32 before transferring the file.
Steps to Install OSM France Maps on a Micro SD Card​
1. Download the Map File​
  • Visit a reliable source for OpenStreetMap (OSM) maps.
  • Look for the France map file, which is typically named gmapsupp.img.
  • Download the file to your computer.
2. Prepare the Micro SD Card​
  • Insert the micro SD card into your computer using a card reader.
  • Ensure the card is formatted to FAT or FAT32. This can usually be done through your computer's file management system.
3. Create the GARMIN Folder​
  • Open the micro SD card drive on your computer.
  • Create a new folder named GARMIN if it does not already exist.
4. Transfer the Map File​
  • Copy the downloaded gmapsupp.img file into the GARMIN folder on the micro SD card.
5. Final Steps​
  • Safely eject the micro SD card from your computer.
  • Insert the micro SD card back into your Garmin device.
  • Power on the device and check the map settings to ensure the new map is recognized.
Important Notes​
  • If you want to add multiple maps, you can rename the files to something memorable (e.g., France_Map.img) before copying them to the GARMIN folder. This is especially useful for newer Garmin models that can handle multiple map files.
  • Always ensure that the total size of the map files does not exceed the capacity of the micro SD card.
Perhaps get assistance from some young student type or a IT graduate close by, sometimes a local library has help, or knows someone that can. Good luck.
Try here, will download as a ZIP file, (quicker method too receiving files) and need to be opened to view.
Plenty to choose from.
Again it is easier to have someone computer literate, for this process to be effective, but once shown it's a simple operation.
Still struggling , here is easier and more help.
To put a copy of OSM France maps onto a micro SD card for a Garmin DriveSmart 55, download the map file and copy it to the GARMIN folder on the micro SD card. Ensure the file is named correctly (like gmapsupp.img) and that the card is properly inserted into the device.
garmin.com
Steps to Install OSM France Maps on Garmin DriveSmart 55​
Requirements​
  • A computer (Mac or PC)
  • A micro SD card (4 to 32 GB)
  • Garmin DriveSmart 55 device
Installation Process​
    • Go to a reliable source for OSM maps, such as the Freizeitkarte website.
    • Select and download the map file for France.
  2. Prepare the Map File
    • Unzip the downloaded file if it is compressed. You can use software like WinRAR or WinZip.
    • Ensure the file is named correctly, typically as gmapsupp.img.
  3. Transfer the Map to the Micro SD Card
    • Insert the micro SD card into your computer using a card reader or connect the Garmin DriveSmart 55 via USB.
    • Open the drive corresponding to the micro SD card.
    • Navigate to the GARMIN folder on the micro SD card.
    • Copy and paste the gmapsupp.img file into the GARMIN folder.
  4. Final Steps
    • Insert the micro SD card back into the Garmin DriveSmart 55.
    • Power on the device and check the map settings to ensure the new map is enabled.
Important Notes​
  • Make sure the file size does not exceed 2 GB, as this is the limit for individual maps on Garmin devices.
  • If you want to add multiple maps, you may need to rename the files to avoid overwriting existing maps.
garmin.com OpenStreetMap
Good luck, below is link to freizeitkarte
All done.
Very easy once I was pointed at the Zip files but couldn’t make head nor tail of it from the actual OSM site, and me with 36 years IT experience, Doh 🙄
Thanks for your help lads. I’ll add more of Europe as I need it. 😊
Glad you got there, 36 years helped :green gri
I am still learning IT, that is why I like it so much, an ever changing world.
