P.C can't see Scala Rider G4
mediamark
Sheffield
Hi folks
I bought a new laptop a couple of weeks ago and am slowly installing all the software I use on it.
For some reason, after installing the Scala software, the laptop cannot see the G4 (yes, it is turned on - flashing blue light etc!)
Any suggestions please?!
I know you said you turned it on, but you have to turn it on in a slightly different way to connect to the PC, not just power it on as normal.
I can't remember the exact details but the popup box does tell you how if it can't see the G4.
Dae
I've turned it on as per the on screen instructions, pressing the +volume & middle button together. The G4 is on but the pc doesn't recognise its there. I've even tried another cable!
Might have to try re-installing the software.
Via Tapatalk
Managed to sort the problem. It was a driver issue.
For some reason, the Windows 7 Bluetooth driver was overriding the Cardo bluetooth driver.
Sent via Tapatalk 2
