Off to Europe soon. Front pads look fine, rear outside is ok but inside is quite thin. Can't see through the holes in the back so might chance it. Does the back brake come on with the front on a 2011 twin cam. Hardly use the back.
Yes the brakes are linked. If one pad is much more worn than the other there is something going on.
Yes the brakes are linked. If one pad is much more worn than the other there is something going on. I'd remove the pads and examine them and check calliper is free to slide. Make sure the piston is free and have a good clean up. If the pad or pads are well worn I'd replace them seeing as they are out already. Hopefully that should sort out your back brake so have a look clean up the front while you are in there. JJH
I've got a 2011 twincam without ABS, are the brakes linked on it ?
How much does a set of pads cost?Off to Europe soon. Front pads look fine, rear outside is ok but inside is quite thin. Can't see through the holes in the back so might chance it. Does the back brake come on with the front on a 2011 twin cam. Hardly use the back.
Can you swap the rear pads around so the one which wears more quickly has the one with the most left on it?
""" Couldn't get any on the way so removed the calliper from the mounting and strapped it to the bike for the remainder of the trip"""
I was caught out with rear's down to the metal on a trip to Spain even though I'd fitted new before leaving. The replacements must have been rubbish. Couldn't get any on the way so removed the calliper from the mounting and strapped it to the bike for the remainder of the trip. The only worrying moment was riding down a very steep wet ramp into the ferry when a rear brake would have been handy.
Just had my bike serviced and the rear pads had an amber warning and 1.9mm. Question is how many miles roughly will this equate too?
I've got a trip in the region of 2500 miles in a couple of weeks,But I'm guessing BMW would have changed them if they would not reach next service interval at 6k?
