Paging Mr Ram-man ...
oblertone
Strawberry fields ... forever
Mid Devon
... Dear Sir, I need balls, in fact I need two of them, the ones that clamp to the rear of the Zumo bike mount. I think I've already got the rest of the gubbins, unless of course you supply a dedicated RAM mount for the Tmax, otherwise I'm just going to drill the handlebar cover and bolt it on :augie
ps - what's the url for your website ?
Paul,
Drilling :eek: that's a bit drastic when all you need is screwdriver :blast:D
I assume from the description that's its a big boys scoot, the Yamaha Tmax 500 ;) which is similar to the Silverwing and Burgman in so much as the simplest way to mount is on the fluid reservoir cover, LHS :augie, as the two hole fixing is in the centreline (common on Jap bikes and these scoots) so two options, RAM-B-345 or RAM-B-346.
I would use RAM-B-346 as the centreline holes are elongated (twice size length of RAM-B-345) so allows you more play or tolerance when aligning up. Cast post is at the side end so fit towards the clocks. You can get from www.gpsw.co.uk
The arm, base plate from the mount in the box can be used from GS to scoot. If you need to replicate on each, then arm is RAM-B-201 or RAM-B-201-A (short) then round base is RAM-B-202 or try RAM-B-347 (which is AMPS base plate) which attaches to the cradle.
Steve
Top man ...
... I'll be off ordering asap :thumb2
