Chrizm
Well took bike in today for its 1st MOT since I bought it and I got an advisery for rear wheel bearing. Had a good read about it and have come to conclusion its the paralever bearing. From spending last few hours reading about how to adjust this I have a few questions which are not quite clear to me as follows:
1. I understand I need to heat up the lock nut and allen drive bolt to loosen up the lock tight, I assum I need to remove the wheel for this?
2. Do I need to remove the rubber gaitor first as this may melt, if so do I need to drain out oil or is this section dry?
3. Ive read that this needs torquing up to 7nb, is this right? Or do I just turn it in a bit until the play has gone?
4. Do I need to fully remove the allen bolt and locknut to clear off the locktite?
I know my spelling is crap, forgive me its late....well early
before tightning the lock nut back on and putting all back together. Doing a few other little jobs like stripping callipers and re-sealing exhaust while im at it then I might post some picks of the beak conversion I did later
