PC not connecting to wifi
Baz
West Yorks
Morning all
I have had to move my PC from its usual location which was hard wired to my router. I am trying to use wifi to connect to the internet without success. My PC is able to see the wifi from my router and iphone, however when I input the password try & connect to either source or my mifi unit, I get the message " Can’t connect to this network".
PC will only connect if using the RJ45 cables
PC is running windows 10 I can’t see anything in the settings to alter. Am I missing something?
Ta Baz
Have you tried to run the 'troubleshooter'?
Right click on the network icon/troubleshoot problems. It normally resolves the basic problems. If this doesn't help, you might need to reset the IP configuration in CMD.
Sent from my CLT-L29 using Tapatalk
If I recall correctly, I just deleted the driver and it re-installed itself. Do a search for your laptop/model and or the the wireless device.
Don't listen to the Wi Fi haters :D
Thanks for the suggestions, no joy though.
