PC specification - is this any good?
Monsieur
Flâneur with style, passion and real substance
London/Lincolnshire
Been offered this as a gaming PC - is it any good? will it play the latest COD games?
PROCESSOR
AMD FX-4 4100 Black Edition 3.6GHz
- 3.6GHz Clock Speed
- Quad Core
- 8MB Cache
MOTHERBOARD
Gigabyte GA-M68MT-S2P
- 8Ch Audio Motherboard
- Up to 16GB RAM
- HMDI & VGA Out
RAM
Kingston 8GB (2x4GB) HyperX 1600MHz Memory
- 1600MHz Memory Speed
- High Speed performance memory
GRAPHICS CARD
XFX HD 6770 1GB GDDR5
- GPU Clock:850 MHz
- Memory Bus:128 bit
- Memory Clock:4.8 GHz
- Memory Size:1 GB
HARD DRIVE
Seagate Barracuda 2TB SATA III 6Gb/s
- 5900 RPM
- 64MB Cache
DVD+R DRIVE
Play and record to DVDR & CDR
Black Case with audio + USB front and back
- Front and back USB
- Front and back audio
FREE Genuine Windows 7 Ultimate
FREE Microsoft Office 2010
Yes it will. COD isn't really that demanding.
As for BF3 then thats another matter. I can't comment on your ATI card as I haven't had an ATI card for years. I'm guessing if you play at 1920 x 1200 then it won't be good enough to have all the games features turned on. Somebody with your set up should be able to confirm this though.
But you asked about COD so I stand with my first paragraph.
My system uses Nvidia cards in SLI with an Intel Quad core processor at 4 Ghz and it runs both games very well in full HD and all aspects turned on full.
I have had a problem with the latest two sets of drivers from Nvidia which brought my system to its knees so I just went back to the last one that worked well. Therefore its not always the hardware that is the problem.
Also on the newer cards heat seems to be an issue so keep your case cool.
I was going to say that is a slow(ish) hard drive but the spec on the seagate site says 7,200rpm.
Can't see the full spec of the machine that you have been offered, key components like RAM (quantity / speed), HDD type / speed - and I guess most importantly cost. Or does offered mean free? If it is the latter then take it
