Dezidero Registered user Joined Jan 1, 2007 Messages 117 Reaction score 0 Location Belfast Norn Iron Mar 26, 2017 #1 hi guys quickest and easiest place to attach said fuse to run autocom Attachments pbfuse.jpg 35.4 KB · Views: 227
mikeyboy Well-known member UKGSer Subscriber Joined Jul 14, 2010 Messages 10,625 Reaction score 4,242 Location S.M.T.R. Craigellachi,Banffshire Mar 26, 2017 #2 That's a nice simple solution
Wapping Well-known member Moderator Joined Oct 21, 2005 Messages 93,738 Reaction score 20,057 Location Wapping, London Mar 26, 2017 #3 You know the item plugs into (piggybacks off) a conventional fuse, usually inside a vehicle's conventional fuse box. You do know your awesome 1200 GS does not have a conventional fuse box, don't you?
Victor c Registered user Joined Jun 29, 2013 Messages 1,396 Reaction score 328 Location North Wales Mar 26, 2017 #4 Wapping said: You know the item plugs into (piggybacks off) a conventional fuse, usually inside a vehicle's conventional fuse box. You do know your awesome 1200 GS does not have a conventional fuse box, don't you? Click to expand... It may not have a fuse box, but the 1200GS LC does have some conventional fuses as standard.
Wapping Well-known member Moderator Joined Oct 21, 2005 Messages 93,738 Reaction score 20,057 Location Wapping, London Mar 26, 2017 #5 Yes, the fuse for the auxiliary lights and the (much larger) fuse for the main ignition circuit. Have a look at the sticky 'Switched power the easy way'.
Dezidero Registered user Joined Jan 1, 2007 Messages 117 Reaction score 0 Location Belfast Norn Iron Mar 26, 2017 #6 Wapping said: Yes, the fuse for the auxiliary lights and the (much larger) fuse for the main ignition circuit. Have a look at the sticky 'Switched power the easy way'. Click to expand... cheers for the heads up .... should've mentioned its a '16 Adventure . my 1st Bmuu so not up to speed on all things (anything) electricky
Gargy Registered user Joined Jan 20, 2014 Messages 1,749 Reaction score 2 Location Gloucester United Kingdom Mar 26, 2017 #7 Under the riders seat there are two fuses. I doubled up on the 7.5 amp one to power a dashcam. Look at my threads to find pic's of the fuses.
Bryn Well-known member Moderator Moderator Joined Sep 20, 2003 Messages 14,087 Reaction score 537 Location South Leicestershire Mar 26, 2017 #8 mikeyboy said: That's a nice simple solution Click to expand... I put one on my 1150 to power the autocom... works a treat
Phil-H Registered user Joined Jul 10, 2012 Messages 1,158 Reaction score 0 Location N.Yorks Mar 26, 2017 #9 Dezidero said: hi guys quickest and easiest place to attach said fuse to run autocom Click to expand... What a simple, neat solution to a common problem.
Victor c Registered user Joined Jun 29, 2013 Messages 1,396 Reaction score 328 Location North Wales Mar 26, 2017 #10 Gargy said: Under the riders seat there are two fuses. I doubled up on the 7.5 amp one to power a dashcam. Look at my threads to find pic's of the fuses. Click to expand... That would be the 7.5 amp for the left multifunction switch and tyre pressure monitoring system. The 10 amp is for the dash and alarm system.
