Portable motion detector
Rugged Path
The Honourable.
Wybunbury, Cheshire East, England, EU
My R1150GSA does not have an alarm so, either use a chain or disc lock. Most of the time parked up on the side stand.
I would like to consider buying a small motion detector alarm that can be recharged through the bikes external socket outlet. And when using it, switch it on and attach via Velcro somewhere on the bike while away. For example, under the top box, under seat, under beak or under engine bash plate.
If someone tries to lift it vertical, it goes off.
Is something like that available?
Sent from Steve's fancy iPad using Tapatalk
Found this simple and cheap device. Charge at home.
Park up, switch on and stick somewhere discreet on the bike.
***On second thought it is infrared and may not work if hidden***
