Possible dodgy injector - Advice please.
G5RJO
Middle England
05 1150 Adventure, suddenly running very rough, left cylinder drops out.
Swapped over the primary and secondary coils, no change.
Strong spark and the plugs on the left are soaking wet.
Pulled the left injector, and as soon as the ignition is on, it is spraying constantly. Crank it over and it continues to spray constantly. Not the usual pulse, a strong constant spray.
Makes no difference if the electrical connector is disconnected, it's as if the fuel pump pressure is pouring through it constantly.
I'm assuming the injector is toast..... Thoughts?
Roger.
