The great innovation with the
NEW Continental Teves Brakes is:
No power assistance on the lever (FTE before: flawed residual brakes)
Fast valve system (FTE before: slow plunger system)
Well, both innovations was HONDA offering a long time before with the DUAL-CBS-ABS System. The NEW Continental Teves Brakes are nothing special (some journalist wrote that in the daily German newspaper DIE WELT), they just adapted their system to the state of the art braking systems from HONDA. ("BMW Motorrad’s new Integral ABS is comparable with other valve-controlled ABS systems").
"The overall principle followed by BMW Motorrad’s new Integral ABS is
relatively simple: Brake pressure generated manually by the rider via the brake
lever and the main brake piston is transferred via an open valve (the intake
valve) directly to the appropriate wheel brake."
"In the event of any deficiencies in the hydraulic pump or electrical components, the rear-wheel brake acts hydraulically as with a conventional system, overriding the integral function. This has no effect on the proper operation of the front-wheel brake, the only difference being that the ABS function is no longer operative in the event of such a deficiency."
"Malfunctions, should they occur at all, ... Should the electrical or electronic components suffer a deficiency, in turn, the control valves are moved mechanically (by springs) to their basic setting, thus always maintaining a direct hydraulic connection between the brake controls and the brake callipers, as in the case of a conventional brake system without ABS. Under such circumstances the brakes will operate as usual in terms of brake power and application, only ABS control and, where applicable, the integral function no longer being available."
