About six months ago I fitted a K&N filter to my Dakar along with an Adventure (Supertrapp) pipe. The effect was to make the bike breath much better, the acceleration is now much improved.
However, I have noticed that under heavy loads i.e uphill or with touring gear onboard) or accelerating hard between 50 and 70mph in 5th gear can cause some engine knock (pinking). It only demonstrates this behavior using 95octane fuel. If I mix 95 and 97 it doesn’t do it. I had BMW check the lambda sensor, the map and the mixtre – all was fine.
In November I have plans to ride to India and expect to encounter some pretty low octane fuel. Since I will be carrying a small notebook computer I have started to consider fitting a Powercommander so that I can easily reprogram the map for different fuel quality.
Does anybody have experience of fitting a Powercommander to a F650? or have experience using a Powercommander with low octane fuel?
Finally, does slight engine knock (pinking) cause any damage to an engine?
