rodsharp
I had a replacement rear shock some time ago by BMW main dealer Whereas the original had about 20 clicks of adjustment and the handbook suggests standard setting 10 clicks from soft the replacement has 42 clicks. I am not sure of the best setting for this and have been using about 20 clicks ie half way as a compromise which isnt too bad until the pace is upped on crappy roads so just decided to set it to give me the correct level of static sag. The suspension travel is 200mm according to BMW and the sag should be about 30%. This means I need about 35 clicks from soft, ie nearly max compression . That doesnt sound correct to me and its just started raining so wont be testing it just yet. Anyone else experienced this and what are your preferred settings ?
