Prioritise BT on GSA
BillWright
Bucks
Hi. I have the Carpuride & Sena paired via BT to my iPhone. The phone is also paired to the TFT on the bike, which provides the data for the BMW app.
Is there a way to ensure that the Carpuride & Sena are the primary connection? All I want the TFT to do is talk to the BMW app, nothing else.
If it's the same as other things (I have chigee, not carpuride) you shouldn't need your Sena connected to the phone. it's probably that that's confusing things.
Try this:
  1. Connect phone to TFT
  2. Connect phone to Carpuride
  3. Connect Bluetooth headset to TFT
I get all functions of the wheel and the BMW app tracks the route etc.
Connect the Sena to your phone before the Carpuride is turned on. The connection of the Carpuride to the phone is done is via a local wifi. You can see the icon in the top left of the Carpuride screen.
Connecting the Carpuride to your phone via BT can/will nause-up the audio.
Correct me if I'm wrong but the Carpuride needs to be connected to the phone via BT to work as a mirroring device. Does It not?
Try this:
Try this:
  2. Connect phone to Carpuride'
That worked perfectly, thank you very much.
I can't believe how simple it was.
