Anybody had a problem with the fit of the Akropovic SP titanium slip-on can? The SP is the 'budget' version - titanium sleeve with stainless internals and pipe but still weighs in at a not inconsiderable £360.00. Call me tight (and I know you will
) but it seemed a resonable compromise and a damned sight cheaper than the whopping £495 for the BMW/Akro version and the slightly cheaper full titanium Akro can.
The problem is that the rubber bump stop which is supposed the stop the centre stand from smacking up into various parts of the bike - isn't. Consequently, I've now got some large chunks out of the underside of the swing-arm
The problem seems to be caused by the fact that the leg of the stand doesn't strike the bump stop square on - it's offset and this subseqently reduces the amount of clearance on the other side. The foot plate of the stand is literally a couple of mm's from the swinging arm and is whacking it when pushing the bike off the main stand.
Now whilst I don't profess to be the greatest mechanic in the world, I'm now spanner wielding clutz either - there are only two ways to fit an oval can - the right way and upside down! Currently hoping to get this matter resolved between the supplier and the importer. Just wondered if anyone else had had a similar experience? Wish I'd paid the £500 for the BMW version now!
.The problem seems to be caused by the fact that the leg of the stand doesn't strike the bump stop square on - it's offset and this subseqently reduces the amount of clearance on the other side. The foot plate of the stand is literally a couple of mm's from the swinging arm and is whacking it when pushing the bike off the main stand.
