sagalout
Hi,
I decided the treat the TC to a full Akro system, so set aside a few hours to fit it this afternoon.
All seemed to be going ok (apart from the old exhaust / valve clamp bolts shearing off) but the new system doesn't see to fit all that well. I've tried fitting and re-fitting 3 times, including leaving everything 'loose' and tightening with it all in place, but basically the header pipes don't line up all that well with the 2 into 1 section.
I have got it to fit eventually with quite a lot of rubber mallet usage, but then noticed the front header had come away from the cylinder slightly. A light tap knocked it back in, and after starting up there don't appear to be any visible leaks (sounds great too!), but just wondered what others experience of fitting was? I'd expected for the price that everything would fit perfectly, and I don't like the idea of the exhaust being under unnecessary tension.
Headers are new but end can was from eBay - box suggests its definitely the right model :/
I've got a Power Commander to fit next, and a HID kit so hoping they go a little smoother!
