Silverbiker
1999 1150 GS Brembo calliper. bought a new bike but the brakes were working but felt a bit wooden. I thought the calliper a may be seized so I released each one in turn from the discs and found that the pistons moved very freely. Refitted the callipers to the bike and pulled the lever a number of times to settle the pads. On each pull of the lever there was a squelching noise. After about the 3rd pull the brake lever went rock hard with no movement at all and the brakes are now seized on. I released the bleed nipple to release any pressure but this had no effect as only a few drops came out, and certainly no pressure. What could have happened. Master cylinder???
