I will be home later with my Mac.
I’ll see what I can do....
Richard
Richard
Paul,
I doubt if a third party of the map would work as they need to be unlocked and coded to a specific device. If you can get one from Garmin, great.
Richard
Richard what happens if you use the edit function undo, thats presuming you have that on a mac, instead of switching back. it should in theory undo the change.
"We (Garmin) have isolated reports that contain the problem you are describing.
The relevant development departments in the USA have already been informed of the facts. The colleagues there check the problem and work on a solution.
Until then, we would like to ask you to be patient.
Unfortunately, it is currently not possible to make a statement as to when and in what form a solution will be available."
Not much comfort but from the Garmin Users Forum, it’s a Google translation from Swiss...
. I too deleted my previous maps. Hadn't thought of going into Time Machine to get them back though. Thanks for that tip.
It should be OK, Paul.
You may get a message that says something like, “This route was created on different maps. Would you like to recalculate?”.
Click Yes. If it looks OK (same distance, same roads, same shape) you are good to go.
If it looks very different, try again clicking ‘No’ and look again
Either way you’ll end up doing some sort of recalculation on import.
It always helps if:
A. You check ALL your imports BEFORE you leave home, as fixing them are easier now than later. I always import all of mine in advance, display them on the device and check them. The odd mile or two variation doesn’t matter too much.
B. The settings on the device match those on your Mac or home computer
