Hi all,
I recently changed my Anakee's for a set of Conti Trail Attacks on my 07 GSA.
Ever since I have had a problem with a front wheel "shimmy" at 30-40mph. I removed the front wheel and returned it to the tryre fitter to have the balancing re-checked. The balancing was spot on. I have also varied the tryre pressure to see if I could dial the problem out but still no joy.
Any ideas?
I read an article recently which coincidentally was about afront wheel shimmy on a Pan European fitted with Continental tyres (not trail attacks) and the answere seemed to be that they were not an OEM recommended fit for the bike.
I thought the Trail Attacks are a recommended fit for the GSA.
Anybody experienced anything similar?
Any ideas?
Are you using ultraseal, if so do you have the correct amount in the tyre ?
