- Joined
- Aug 3, 2009
- Messages
- 3,034
- Reaction score
- 402
Over the last few months and a spate of Gs and adventure theft, I decided it was time to make up a lock.
I'm still in the design stages at the moment and there is others I may make up which potentially lock different parts of the bike.
It all started with one piece of steel and a couple of hinge brackets
The idea is a plate which will be bolted to a concrete floor in your or work shop.
The hinge idea was to let it open so as not to catch the swing arm and exhaust on the other side but to leave an overhang when closed as not to be able to get to the hinges with an angle grinder (which these thieves seem to carry nowadays).. I know some people like to leave the bike on the centre stand but this is designed for ease and works off the side stand.
The idea is to go with a pin system to go through the rear wheel. I went for 30mm solid bar and then a 45mm hollow bar so I can feed the internal through the external for an extra layer of protection(again for a battery angle grinder)
From this you get the basic gist..
Back in a bit with some more
