Putting waypoints in numerical order in BaseCamp ?
Jockser
Kildare, Ireland
I have a GPX file in Basecamp with 24 waypoints all numbered 1 - 24
However they don't appear in numerical order
I've numbered them 1, 2, 3, etc and I've also tried 01, 02, 03, etc but they still appear in a random order
I know I've managed to get them in order previously but I can't remember how...
PS: I'm on a Mac if that makes any difference
It’s a long time since I used BaseCamp (in a funny way, I sort of miss it) but try:
If you want to create a route from selected WP's, you can always do so, and once created, open the route by double-clicking on the created route.
In the new window that pops up, you can select a WP and change the order in the list of WP's using the arrow up/down on the right hand side. (There is also a + sign with which you can add WP's later at the place where you had selected a WP.)
Is this what you're after....?
If so, it's a simple "Rename" on each one, then they self-sort.
As JoeBiff Says. Photo Rally? The numbers followed by a space/full stop seems to do the trick.
The OP said that numbering them didn’t order them correctly. I guess by this he meant that the points didn’t then route sequentially.
:nenau
:nenau
Dunno I thought he was trying to get the Waypoints for the 2026 Photo Rally together when he said 24 :D
If you fire the file numbered but jumbled, on this thread I'll try and sort it for you. Garmin files can be a bit different than stuff created elsewhere? and it can cause a few issues.
I'm not trying to route to any of them or between any of them. I just need them to appear numerically when someone opens the GPX
This is what I have at the moment -
I can't do that currently :augie
But the file, numbering, etc was created on this Mac by me so I don't understand what's gone wrong
I'm just home so let me try Wapping's original suggestion & I'll come back to you
It's those folk in Down/Armagh awkward hoors........as you know :D
Who are ya telling :blast
So, Wapping's suggestion allows me to change the order within the route I created but the original list, pre-route creation, remains
That's weird the nomenclature of 4. 13 and 21 looks grand. Try exporting the gpx and reimporting it as a separate list back into Basecamp. If they don't come in back in order. Remake those waypoints and see what happens. You still have the original safe then if something goes astray.
I should put you on a retainer :D
The export / import didn't help. But making a new waypoint worked a treat
Thanks all for your assistance :beerjug:
